New to the site, wanted to say how impressed I am with it, especially your courtesy in dealing with all types of questions, as opposed to some forums where newbies are dismissed with a “check the archives” answer.
Here’s my deal…I have a second home in SC, which I keep alarmed and have 6 CCTV type cameras set up. These consist of several Weldex bullets and Bosch box cameras, all good but archaic by IP standards I suppose. I run these through an HP desktop set us as a DVR, with port forwarding allowing me to monitor the property while I’m at home in the Philly area. This is not a great setup, consists of 100 foot lengths of cable running on the floor throughout the home. I did have the foresight to have extra lengths of Cat5e run to each room when I had the house built in the early 2000’s, which terminate in the garage, and hopefully can be used now for IP.
I am quite concerned about the property, as several of the immediately adjacent properties are vacant / for sale and I don’t have the neighborhood watch comfort I used to enjoy.
Here are my questions, and please excuse me for being lengthy…this is a 1500 mile trip to change this system out, with a minimal time window and a small budget, so I want to get it right here and there, which is why I’m imploring your expertise.
Two story colonial type home, main concerns for visibility are front entrance / street area and rear yard which backs up to a wooded area.
1 - Nayr has me sold on the Dahua Starlight Varifocal Turret (IPC-HDW5231R-Z), so I’m thinking that one of these mounted under the garage overhang might sufficiently cover the front being that it has an adjustable focal length lens. With my almost nonexistent budget dwindling rapidly, I was hoping that Dahua might make a decent bullet I could use on the side and rear yards (2 cams)…recommendations welcome.
2 - What are the minimum specs that would be required to set up an NVR, would a Dell Optiplex 790 with 8gb W10 64bit work for the immediate future until I can upgrade to a 5040 i7 or so?
3 - Will the Dahua software (assuming it comes with such) be OK for now, or should I invest in Blue Iris? I am more interested in monitoring than recording.
4 - I have a Dahua HCVR5104H-04-S2 Dahua OEM HCVR5104H-S2 HD-CVI DVR that I bought a while back with some Dahua 720 HD bullets but never used any of it. Is this a worthless piece of junk or can I utilize it in some fashion? Mine only has 4 CCTV inputs and 1TB.
5 - Can I have my existing DVR CCTV setup running alongside of the IP setup on the same network, or is this unrealistic or impossible?.
6 - What equipment do I need to purchase to take with me…I figure the following at minimum –
Netgear ProSAFE switch GS108PE-300NAS to supply POE.
Cable tester and crimper – I have a spool of Cat 5e
Cameras
Comp for NVR or aforementioned Dahua NVR if it’s usable.
Again, sorry for the length, I have been studiously reading posts on this forum trying to garner as much info as possible
Any and all advice GREATLY APPRECIATED! I can even endure name calling or mild insults if my ignorance is too great for you to handle… I’ve been around for a while, have an above average background in LE, security cameras and networking, but still an idiot on too many occasions…
Cameras
