Hello all, been searching but thought this might save time if someone already knew the correct solution.
I need to trigger a siren and light with my TTL alarm outputs. I have a power outlet type of device I can trigger with my TTL alarm outputs no problem but the downside is if a door is opened and the alarm off my DVR triggers the alarm it will not shut it back off. If someone pulls a door open and leaves it that way the siren will go off until someone kills power or the alarm trigger is reset by shutting the door. That will greatly annoy the neighbors, so I want to have a timer that it will only go off for say one minute.
Anyone know of something that will work well? I have found good timers, and I could just add a timer to the DLI IoT relay I have now, but that add complexity. I would prefer one board to do it all as I have to install 60 of these.
