Hi all!
First of all, sorry for my bad english.
A few months ago I installed 3 cameras at my apartment and entryway: one 2cd2432f-iw and two 2cd2132f-is. All cams are chineese, reflashed with multilanguage 5.2.5 by the seller, records to NAS via NFS (HP Microserver with Nas4Free OS) and powered by TP-LINK TL-SG1008P.
At first month everything worked fine, but then it began appearing some artifacts and frame loss in recorded videos from all 3 cams. This effect was increasing: from small lags at first time to this: example1, example2.
![ch01_08000000084000201.mp4_snapshot_00.13_[2016.03.10_11.16.40].jpg ch01_08000000084000201.mp4_snapshot_00.13_[2016.03.10_11.16.40].jpg](https://ipcamtalk.com/data/attachments/7/7416-7b25ebbe3df2e1257780035a883141e1.jpg?hash=eyXrvj3y4S)
But in live-view and SD-card recordings there is no such problems at all.
I've tried to connect one camera directly to notebook with Win10 and set record path to SMB-share, but it took no positive effect (netstat -e shows no errors). The only way I found to stop this is to reset camera settings to default and set everything back manually (when importing last config - problem returns). Anyway, this is a temporary solution, because now 2 of 3 cams again writes with lost frames sometimes.
The things I've already tested, but found useless:
- Changing video settings on cameras and settings on NAS
- Changing patch cables
- Leave only one camera connected to NAS
- Formatting camera storage in Web-GUI
- Powering by POE-injector instead of switch.
What could it be? Which direction to keep digging?
Is there any way to update FW without getting bricked device? It would be enough just english interface.
Thanks!
Thanks!
