I have narrowed down my camera selection to the following 6:
The bullet cams were chosen since the side of my house does not have any overhangs and I do not want to have a large arm sticking out. Does anyone have any suggestions/comments on the lens sizes?
I am also thinking about using my old PC (AMD Phenom II x4 965) with XProtect GO and save about $180 on an NVR (DS-7816N-E2 w/o PoE). The PC I have would not be able to run Blue Iris. Does anyone use XProtect GO with an older system? I would like to run most (if not all @ 3MP, ~15fps). Or would the NVR be better suited than the PC?
- DS-2CD2532F-IS – 2.8mm for front door
- DS-2CD2332-I – 4mm for driveway, 4mm (2.8mm?) for part of backyard, 4mm (2.8mm?) for deck
- DS-2CD2032-I – 4mm (2.8mm?) for side yard and gate, 12mm for 10’x12’ shed @ 50 foot away
