First off, thanks for all the info that is shared here. I have been learning a lot over the last few months reading. But I am confused about POE injectors. Picked up some cameras from Andy, loaded BI on a spare computer and have them running on a test table. Have an 8 port POE Netgear switch I had form another application but need 3 more ports. Ultimately I will eventually replace with a 16 port POE switch but that may be a bit down the road. So I thought I would add a 4 port injector from wifi-texas or similar.
So when looking I find mode A / Mode B and different voltages. This one I am a bit lost. I am thinking this is the one I should get: WT-AT-4-48V60W
Has enough power for 4 cameras, is active so should autosense. But it is mode A. Are Dahua only mode A?
Thanks for any assistance.
