user8963
@pete_c
found this video after i set it up, its mostly the same as i did, but i do not use any NAT modifications...
on android wireguard app you can choose the apps which are allowed to use the tunnel. because its wireguard there is no server/client thing .. make it a bit harder to understand what is going on.
i created a rule that only one device in a vlan is reachable through the tunnel on one particular app. i think more security isnt possible. it does not drain much energy when runninh in background. when i use the app i selected, the handshake is done and it is transfering data. if i close the app nothing is transfered. this is much less stressful as with openvpn where you have to be connected to the server and data is transfered the whole time.. ypu can get over it by using third party apps but still not as good/easy as wireguard.
