As all noobies are advised to do, I made a test rig from a bucket, rocks, and a 2x4. Not content with the original version, I made a lot of special modifications myself.
One problem I had with v1.0 was that after moving it around a few times, rocks got between the wood and the bucket, making it lean. I wanted the 2x4 in the back of the bucket so it could be set closely against a wall to more accurately simulate final placement. Solution: Three #8 x 1.5" screws through the bucket.
I used lava rocks to keep the weight down but still provide ample ballast. Be sure to install the 2x4 so that the handle isn't trapped behind it.
I have a patio cover and some low eaves that I needed to test under. An 8ft 2x4 wouldn't fit, but I also needed to test some slightly higher positions. Solution: Make a two stage test rig!
I attached a 2nd piece of wood to the end of the first with a hinge. Eyes on the side allow a thick cable tie to keep the upper piece extended. The hinge is attached so that the top piece flips down over the bucket, improving balance. In the down position, it's about 7'4" and about 9'1" fully extended. The holes in the wood are for the pigtail, allowing me to bring the camera in at night for safe keeping without removing the base.
