- Nov 30, 2017
- 187
- 96
Hey IPcam friends...i will now buy additional items. Here is what I have so far. Please provide your input if it’s not the right thing to get. Cam installation is not my profession so if any of this is an overkill, please share a link with your recommendations. I will route the cable through the walls and in the attic. I have also purchased some ubiquiti networking gear so this cable will be used for that purpose as well.
Lastly, I was told 23 gauge is good for long runs over 24 gauge . Cable below I chose is 23 gauge.
I’ve seen @fenderman recommend platinum products so chose those for connectors and crimpers.
bulk monoprice network cable:
Monoprice Cat6 Ethernet Bulk Cable - Network Internet Cord - Solid, 500Mhz, UTP, CMR, Riser Rated, Pure Bare Copper Wire, 23AWG, 1000ft, White - 108108 https://www.amazon.com/dp/B007NHJODC/ref=cm_sw_r_cp_api_i_7PdgCb3GN3TEK
Platinum connectors:
Platinum Tools 100010C EZ-RJ45 Cat 6+ Connectors, Clamshell, 50-Pieces https://www.amazon.com/dp/B000FI9VU2/ref=cm_sw_r_cp_api_i_1UdgCbZNEEZSS
Platinum crimp tool:
Platinum Tools 100054C Clamshell EZ-RJPRO HD Crimp Tool https://www.amazon.com/dp/B00939KFOU/ref=cm_sw_r_cp_api_i_DlegCbZPZY3ND
Cable tester:
I have NO clue which one to buy, please recommend.
Cable routing tools.
I saw these that have very high ratings
11' Fiberglass Running Wire Cable Coaxial Electrical Fish Tape Pull Push Kit https://www.amazon.com/dp/B07519CLJX/ref=cm_sw_r_cp_api_i_37dgCb5S71XRZ
Cheers !!
Cable tester:
Cheers !!
