My new replacement DH-IPC-HDW2431T-AS budget cams
dudemaar
1,324
2,826
Canada
Just ordered in some new budget DH-IPC-HDW2431T-AS cameras from Andy to replace my old Dahua N41BK22 I've had for many years. Did some day/night comparison snapshots and thought i would share . I also have some extra IPC-HDW2231R-ZS and IPC-T5241H-AS-PV kicking around for a upcoming install i threw in the mix too. Not sure if i'm doing this right, but every camera was at factory default settings for snapshots on web interface.
only spec sheet I could find on the DH-IPC-HDW2431T-AS (firmware upgrade able)
Unboxing
Plastic base and skirt.
comparisons
Night time
iphone 6
My old Dahua N41BK22 (4MP)
My new DH-IPC-HDW2431T-AS(4MP)
IPC-HDW2231R-ZS (2MP)
IPC-T5241H-AS-PV (2MP)
Day Time
to be continued..........
These budget cameras are quite useful and easy to recommend to folks that ask me what to install with a tight budget in mind.
Reactions: Grn1z
Anyone found the firmware for this?
If you download the Word file that's attached to the first post it should have a link to Dropbox in it for the firmware.
Hi Denovich & Dudemar What model and What Lux did you get?
I cant find the specsheet anywhere either!
I presume you both got the non s2 model which appears to have a .008 lux as opposed to the S2 model which according to spec sheet above has only .01 lux?
Does the box or contents confirm the lux?
Perhaps Andy can send you the specsheet?
