Ironically my earlier thread about replacing my RAID 5 storage server with a FreeNAS box was lost when ipcamtalk suffered a disk failure.
My new box is a Xeon E3 system with 24 GB of ECC RAM, based on this Lenovo server: http://www.amazon.com/dp/B00FE29IWK
Lenovo did a pretty good job with this server, considering it is actually quite low-end. It is one of the quietest desktop machines I've ever run and there were zero problems getting it running smoothly. Memory testing over two nights indicated no errors so I think I'm all set.
I installed 4 Western Digital Red 6 TB drives inside it this morning and configured them as RAID-Z2 in a fresh FreeNAS installation. This type of RAID sacrifices the capacity of two disks, and provides protection from any two disk failures. Total usable space is just 10.3 TB, a bit less than I was expecting for a "12 TB" pool considering my old "9 TB" pool has 8.18 TB usable. The resaon, I suppose, is the file system. My 9 TB pool uses the NTFS filesystem, while my 12 TB pool uses ZFS which evidently has higher overhead.
Read and write speed are both 100+ MB/s with this new setup, limited by the 1 Gbps network interface. This pleases me greatly. Previously I always used RAID 5 with my storage servers, and suffered abysmal write speeds around 20 MB/s. I've tried the included disk benchmarking tool in FreeNAS, but it is a command line tool and I wasn't able to make much sense of its output... or its input for that matter. What matters though is that this maxes out the network interface, and any additional disk speed on top of that is just gravy.
So far, the CPU usage graph doesn't show anything reaching 20% so I know I chose a fast enough system. It is even using lz4 compression on everything that goes onto the disks. That is pretty cool. I'm sure this machine will handle more CPU-intensive tasks like media transcoding with ease.
