Hi, what a fantastic place ipcamtalks. I knew there must have been a resource out these that covers it all
So, here I am after reading loads of posts and getting to grips as to where to start. I've read bits & pieces of common mistakes too.It's a minefield ....
This are my goals:
a) set up a IPcam surveilance with 8 cams outside most and about 4 inside which point to the main entrances.
b) no chinese cams despite me having a segragated virtual LAN setup for my Cams and home automation (openhab). I'm just not having it. I know Amcrest and EmpireTech are OEM chinese stuff but as least the firmware is not chinese. I guess there is no US or EU manfactured device? ##Open off topic!##How has this world ended up relying on China so much?##Close off topic!##
c) NVR to be software based on miniPC or similar, with software Open Source as a MUST. Not sure if I run it on dedicated NUC or whether I get a VM spun up on Proxmox NUC running VM (latter would be easier to manage with backup etc.)
d) probably leaning on Frigate for now as seems to have good OpenHab integration and Blue Iris is a no goer as it require Windows. Strictly LINUX in my home ... Zoneminder seems to be a nightmare for configuration from what I've read. Motion .. not sure compared to Frigate.
My BIG Questions:
1) seems like camera as are big point of debate. I live in EU and there don't seem to be a lot of online retailers that sell to private nerds that like DIY. Amazon or eBay seem to be the only sources I can find (Duhau and Hikvision suppliers only sell to businesses but these are chinese so probably woulnd't buy.). Is anyone here aware of good IP PEO camera suppliers in the EU? Are there any EU people here that have successfully purchased in the States without having to pay customes surcharge? I think if the purchase is <150 euro you don't get customes import applied?
2) I'm left with Amcrest and EmpireTech. Reolink doesn't seems to be well rated. And its also chinese? The latter is dependent on my previous questions where as I can get my hands on some Amcrest. The only model I can easily get my hands on as a test risk is the IP5M-T1179EW-28MM. I know its not ideal, as a varifocal would have been better but will have to live with it as a test rig unless anyone can usggest something better that is easily obtainable in EU.
THanks
This are my goals:
My BIG Questions:
THanks
