I can't fucking configure a static ip, change my password,update firmware, i can't do anything .
I tried TFTP,FTP ,VMS 2000, etc.
When i reboot it keep asking for wizard assistant and i already deactivated this thing omg .
I want to throw away my dvr.
It's a turbo 7116 hghi e dvr 16 ch.
Do you have it disconnected from the Internet when you are attempting these setting changes?
Do you have ports forwarded in your router for remote viewing, when it's working normally?
1.- It's connected to the internet but I tried to factory reset it many times while i disconnected the cable.
2. Yes i have ports for remote viewing , i use Hik connect.
I will try to remove the battery
