Well im kinda new to the hole camera thing, but upon testing Blue Iris and 7x Hikvision cameras.... i just fell in love with it, and Pentium G3220 was not able to move Blue Iris with 7x 1080p streams at 15fps. With Intel releasing devils canon, decided to to update my desktop freeing the 4770K, i did have some of the components already from a HTPC that no longer in use, but did buy some.
CPU = Intel Core i7-4770K
CPU Cooler = NoFan CR-95C Black Pearl Fanless CPU Cooler
Memory = G.Skill Sniper 8GB DDR3 1600
Memory heatsinks = 2x Enzotech Pure Forged Copper Memory Heatspreaders (had to buy them as the snipers were too tall to fit below the Nofan95)
Motherboard = MSI H81I
FANs = Noctua NF-A14 PWM + Noctua NF-S12A PWM + Noctua NF-A9x14 PWM
PWM fan splitter = Circotech PWM Fan Splitter
CASE = LIAN LI PC-Q08B
PSU = picoPSU-150-XT + 150W Adapter Power Kit
SSD = Intel X25m 120GB
HDD = WD 4TB Purple WD40PURX
Suspension = NoiseMagic NoVibes III Silent Hard Drive Mounting System
OS = Windows 7 home premium
Software = Blue Iris 3.8
Since there was no direct hdd cooling on the case for the way i wanted to mount the hdd, decided to do some light modding adding a bottom fan to the 5.25 cage,
Some pics of the build,
The fans are controlled by MSI Bios, they idle at 12.5% around 200rpms and core temps are usually at 30C. Prime95 does punish it though, reaching above 80C on some cores, but still is stable at 3.7ghz on all cores.
I leave you the power consumption of the wall using a Killowatt P3 under different scenarios,
If you have any questions let me know,
