Hi,
I currently am using AVS Pisso i3 with 10 cameras.
8 AVS 3MP IP Cameras
1 Openeye IP Camera
1 Axis M3011 IP Camera
The CMS Software is running very slow. It crash a lot and it takes forever to playback the video footage.
Will this solve the problem if I using Blue Iris?
I am using trial demo version, Openeye and Axis camera is working but I can't make connection to AVS cameras. I tired using Generic and no luck. User ID and password is correct. Ports are correct as well. I keep getting "No Signal" or HTTP:404 Not Found or RTSP:301 Unauthorized.
I can connect to each AVS Cams and view.
Do you have any other suggestion?
Port have checked port numbers and RTSP port as well.
Thanks!
1 Openeye IP Camera
Thanks!
