I moved into a house that has an AIPhone AX doorbell and intercom system.
The central unit that receives doorbell videos can only produce analog video signals through BNC ports, which are not amenable to integration with Blue Iris.
As an alternative, I'm thinking of ways to hijack the video signal directly from the cameras.
It so happens that the door cams feed videos to the central unit through CAT5e cables, as illustrated by the diagram below.
Is there any way to isolate the video signal from the CAT5e cable, so that I will have digital, as opposed to analog, video signals, which I then can feed to Blue Iris?
