Hello,
Long time lurker here finally registered and joined to further my knowledge. I've played with NVR/DVR systems for a few years now but now have a project that I need some help with. I have multiple construction sites I am trying to monitor and need a security camera solution. I am trying to setup multiple IP Cameras that are remote to connect to Blue Iris. I don't have to use Blue Iris but from what I've read and after playing with it, it seems to be a solid program. I have already purchased some equipment to try and setup but not having much luck. What I am trying to accomplish is using T-Mobile business internet w/ static IP's on my construction sites to connect to the IP cameras remote with Blue Iris. T-Mobile business internet uses a Inseego FX4100 Cellular router w/ a 5g connection and also provides me a static IP. I have a dedicated PC to run Blue Iris which is located at my main office. I plan on standing camera poles that will hold either 2 or 3 IP cameras. I am able to provide power to each camera pole as well. Each Pole will have its out Inseego FX4100 Cellular router from T-Mobile that has its own static IP. Each camera pole will also have a Unifi Switch Flex connected to the Inseego router that will provide POE power to the IP Cameras. Does anyone have any suggestions on how I can accomplish this with the equipment I have or do I need to look for different equipment. Example of my hierarchy below. Any suggestions or tips would be greatly appreciated as I have a lot of activity going on that I am trying to monitor.
- Dedicated PC at Main Office W/ Blue Iris (Has its own static IP)
- Construction Site 1
- Camera Pole 1
- Inseego FX 4100 Router 1 W/ Static IP
- Unifi Switch Flex
- IP Camera 1
- IP Camera 2
- Unifi Switch Flex
- Camera Pole 2
- Inseego FX 4100 Router 2 W/ Static IP
- Unifi Switch Flex
- IP Camera 3
- IP Camera 4
- IP Camera 5
- Unifi Switch Flex
- Camera Pole 1
- Construction Site 2
- Camera Pole 3
- Inseego FX 4100 Router 3 W/ Static IP
- Unifi Switch Flex
- IP Camera 6
- IP Camera 7
- Unifi Switch Flex
- Camera Pole 3
- Construction Site 3
- Camera Pole 4
- Inseego FX 4100 Router 4 W/ Static IP
- Unifi Switch Flex
- IP Camera 8
- IP Camera 9
- Unifi Switch Flex
- Camera Pole 5
- Inseego FX 4100 Router 5 W/ Static IP
- Unifi Switch Flex
- IP Camera 10
- IP Camera 11
- IP Camera 12
- Unifi Switch Flex
- Camera Pole 4
- And so on......
