So I’ve setup a BI server which has a 256gb SSD for the OS and 2 2Tb drives for storage. Looking at the config dialogs it suggests that I should point New and the Db at the fastest drive, so the SSD. When this hits a limit I can then tell it where to then move the vids to. How then can I utilise the 2nd drive for storage?
I have read various threads including one where the suggestion was to RAID the drives but I’d rather keep the drives as simple basic drives as opposed to RAID 1 where if 1 drive fails you loose the lot.
The only way I can think of doing this is to create another New folder, say New2 on the SSD and set this move vids at the limit to the 2nd drive. I can then set half the cams to use New and the other half to use New2.
Is my thinking above correct or is there another simpler way to make use of both of my drives?
