So a bit of a lurker, and new time buyer of the Costco Lorex Kit.
I have some questions about how best to run this.
First thought
1) Attic, I am pretty sure I can get all cables to the attic, but I don't have any "AC Power" there, so I cannot plug into the PoE ethernet. So you say, Run the cables to the attic then run all 6-8+ network cables DOWN into some other room. Problem: I have a two story house, attic above the Bedrooms, no attic over the "living" room that has most the network, nor the computer room that has the rest.
So I kind of scratched that IDEA
2) Run all cables to the attached garage, not too difficult. Though the cameras that are on the "right" side will be either very long to run along the frame of the house, or up to the attic and through the attic to the other side and then down. Slight problem. Bigger problem: Have only 1-2 outlets in the garage to plug into, no other computer/networking stuff is in the garage. Probably be able to drill a "square" size hole in the garage and be able to go through both drywalls to have direct access to the networking stuff, but not sure if I run the 8+ cables through the wall (more on this later) or put the PoE switch in the garage somewhere somehow, and then run just one cable to the router/switch. If I run the 8 cables THROUGH the wall, what is the best way to do that without making the hole HUGE? (more on this later).
3) This is what I wanted to do, but when I came to the end I ended up with a problem that I wanted to ask here.
Run all cables 8+ to the LEFT side of the house. Either along the rafters/roof, or up through the attic and then down. This will terminate on the side of the house near the computer room that I can drill through the OUTSIDE wall and connect to the PoE/Switch. Here is the "same" problem as above. I will need to run 8+ network cables through this "hole". I was thinking, put a junction box on the "outside" with the PoE inside and run the ONE network cable and the ONE power cable through a "small ish" hole.
OR (i am not sure how these work) put a "keystone" connector on the outside where the cables terminate and then 8 more cables on the inside to the PoE (though I don't know how this would make the whole any SMALLER).
Which leads me to ANOTHER question. How big of a conduit do I need or would I need to probably at one point have all 6-8 ethernet cables in ONE conduit, and do I crimp the cables BEFORE pulling them, or After (since I want so many in one?)
Any other tips on how to run this?
First thought
