Ok, so I'm currently designing a system that I'm going to install in my casa. I have most of the mats purchased and have all of the rough in cat6e ran. I'm having issues figuring out what equipment I will need to complete the install, specifically the remote cams.
The system itself is a REOLINK NVR with several PoE cameras. All but 3 cameras will be home run to the NVR, but I have 3 cams that will be connected to the NVR via a TPLINK microwave shot (5Ghz 300 Mbps Outdoor CPE). The connection flow will look like this (I'll use question marks {?} to denote where I'm not sure what equipment I will need): NVR -- cat6e -- ? -- Microwave Shot -- Microwave Far End -- ? -- Cameras x 3. Basically, how do I multiplex the cameras for the shot then how do I demux them at the far end for distro to the cams. Router and some switches? Is there a cleaner way to do it? The NVR is PoE and pretty much everything is in the system.. how will I deconflict PoE voltages??
Thank you for the help all.
