Hello, I can use some help or guidance when processing an MQTT trigger in BI 5.
In 4, I used to be able to do this: mosquitto_pub -h 10.9.234.72 -t BlueIris/admin -m "camera=PF&fullscreen=1" and my camera designated as PF would expand fullscreen.
I use MQTT triggers for various events (door openings, motion, sound, etc.) But in BI 5 running exactly the same after upgrade, this command only highlights the window but doesn't go fullscreen.
Any help or suggestions or settings that I'm missing?
Thanks much in advance!
I neglected to mention that on the above implementation under BI 5 I'm running BI as a service normally and then opening the client to display the camera feeds, triggered fullscreen does not work.
When I disable BI as a service and run as a native app, fullscreen now works as expected.
