Hello All,
I have a SANNCE 4 channel NVR with 4 IP camera's. To prepare to move them over to my hikvision 8 channel NVR here is what I did:
1. I logged onto the SANNCE NVR. I changed over all of my cameras to ONVIF port 80 and assigned a static IP address
2. I can see my SANNCE and my Hikvision on my network (both have different IP addresses).
3. I can see all of my IP cameras on my network with static IP addresses. I can use ONVIF viewer to see my camera feeds.
Here is my issue:
When I unplug my cameras from the SANNCE and plug it into the Hikvision. The Hikvision NVR ethernet lights do not light up at all. If I plug the camera back into the SANNCE the camera gets lit back up and I can see it again on my network.
I have tried connecting a laptop to my Hikvision and ran SADP, but the Camera is still not detected since there is no green light on the ethernet port.
I tried all 8 ethernet ports and none seem to light up.
I also tried purchasing a separate tp-link TL-SF1009P 8 Port POE switch and tried installing the cameras to it, but the lights don't turn green either.
Are my SANNCE camera's not compatible with anything other than the SANNCE NVR?
Here is my issue:
