Windows 10 was about to crash and burn, so I backed up my setting and copied out the .bvr video files from the NEW folder and placed them on another drive. I ended up having to do a factory reset and reinstall Windows 10.
I copied the NEW folder back into the new BI install, but they didn't pop up in the clip viewer on the right side of the screen. That is when I realized that there was a db folder I should have copied out also.
Is there any way to get these file back into the Clips section of the BI GUI?
