At the moment I am running BI on an i3 8100 with 16GB of RAM and for my usage it is perfectly fine, but I use the system for other things as well and was thinking of setting up a detected BI box. I am in the process of building a high end gaming PC for a friend and they have no use for the old system which is a Intel 4460 with 8GB RAM, storage etc isn't a problem.
I was thinking of taking the system for a detected BI box, but my concern is my cameras all use h265 which as I understand is not supported on Intel 4th gen. At the moment I have 5 cams right now but will not go above 8 for sure. I am not using any BI motion features or AI as of yet, but if the system allows it then would be interested in looking into it in the future.
I was thinking bumping the ram up to 16GB as that cost is minimal but overall would you recommend this move or have other suggestions?
