Mouse pointer in desktop capture
Geovos
Sep 25, 2017
2
Hello,
I am using desktop capture on Blue Iris. Is there a way to capture and record the mouse pointer?
I have not managed to locate anything in the settings or the documentation.
Many thanks!
Hello,
Many thanks!
If you are using Windows 10 you can use the built in Screen Recording Software, that captures mouse movement in Blue Iris.
many thanks for the responses!
I think if you turn on pointer trails in the OS's mouse settings (minimum trail length is fine) that has been known to make the pointer be visible in some desktop capture apps.
I had heard about the pointer trail thing, but it does not work in this case.
That sounds really interesting, but I'm not sure I am getting it. Is there a way to feed the Windows 10 screen recorder into Iris? How would I go about it?
Once again, many thanks for your time.
Sorry I thought you were trying to record your Blue Iris display with the mouse pointer visible for some training video you may have wanted to create... Sorry my misunderstanding.
