I am in the process of trying to order a SD59430U-HN <---my thread.
I will be mounting the camera on an outbuilding that already has power and networking equipment to support an older Panasonic IP cam, and a Davis Vantage Pro2 weatherstation. I have the weatherstation mounted on a 10ft length piece of 1 1/2" diameter "rigid conduit." This pole flexes fairly easily in the wind, and isn't a problem for the weatherstation. However, I wonder if I should install guy wires or braces to stabilize the pole for better camera images. Here are some pictures of my current installation:
Front view
Mount on rear of building
Full image of installation
So, I'm obviously thinking about mounting the camera just under the weatherstation.
I really appreciate any advice you folks would be willing to offer.
Thank you,
David
Front view
- Am I going to be able to secure a pole camera mount to a spindly 1 1/2" diameter pole?
- Should I use eye lag bolts driven into the roof and braided steel cable, or some type of rigid metal brace?
- Are there purpose built roof mounts that would be a better choice?
- Should I redo my existing installation with a more rigid pole that wouldn't require stabilizing?
- Are there direct camera mounts designed to be installed on a shingled roof that would be more appropriate?
Thank you,
David
