M mark4470 Young grasshopper Jul 29, 2016 69 10 Aug 12, 2016 #1 I'm looking to buy a couple exir turrets, can they be wall mounted? Are they a pain to adjust that way?
PSPCommOp Getting the hang of it Jun 17, 2016 688 92 Northeastern PA Aug 12, 2016 #2 my suggestion, a bracket like this... http://www.aliexpress.com/store/pro...era-ds-2cd2332-I-and/1747374_32356682737.html Mounting them flat to the wall gave me an angle I didn't care for. If you're looking to record straight out from where the turret is, flush would work. But if you want an angle, I'd def go with something like I listed above.
fenderman Staff member Mar 9, 2014 36,891 21,410 Aug 12, 2016 #3 The turret can easily be mounted on the wall and pointed in any direction...you dont need the mount..its no different than a bullet..
