Mount hikvision bullet cam to outlet box.
sdiamond808
Jul 2, 2017
118
14
Builder ran ethernet to an outlet box. Looks just like a light switch box. 4.5 inch rectangle with screw holes in the middle ofnthe short sides.
Which junction box will work with this? I can't find the information online.
Which exact model of Hikvision bullet?
The model is DS-2CD2043go
The issue i am having is which junction box will hook to an electric wall box
Hi @sdiamond808
You may need an adapter plate .. or perhaps a 3rd party box .. or you may need to DIY mod the Hikvision box ..
