Is this a reasonable mount to use for T54IR-ZE-S3 on a vertical brick wall? I'm not sure if this is a cheap knock off, or the same thing empiretech sells?
empiretech01.com
If it is indeed a PFA130-E yes.
I prefer this one
EmpireTech PFB203W Wall Mount Bracket
Aesthetic design Wall mount bracket Material: aluminum & SECCempiretech01.com
You mean the PFB203W? What about for mounting vertically on wood siding?This one is much easier to work with and line the camera up for the field of view you want.
Ford vs Chevy, whatever floats your boat.
I agree, the wall mount bracket looks more professional IMHO.If it is indeed a PFA130-E yes.
I prefer this one
These may work fine but they are plastic whereas Andy's empiretech are aluminum.Is this a reasonable mount to use for T54IR-ZE-S3 on a vertical brick wall? I'm not sure if this is a cheap knock off, or the same thing empiretech sells?
