- Oct 25, 2015
- 4
- 0
I just setup BI today and most things are working well. However, I keep getting files labeled as "Motion" and it gives a length such as "10sec". Then when I click on that file it is just a still image and not a video. I have the JPGs showing up correctly.
Then I get the bvr files which seem to be self-explantory: they are recordings of motion detected in the cameras. Those play back as they should.
So what is the difference between the two files and how do I shut off the Motion files as I don't think I need those?
One other thing, I have turned my alerts settings to "Never". I don't really need alerts, I just want video that I can look through at the end of the day if anything happened around the house. But it is still recording alerts into the alert folder.
Thank you for your help.
