- Oct 18, 2016
- 74
- 1
In recording/Schedule Settings, there are options to record continuous, motion, alarm, and event. I am assuming it will record any event, including standard motion and line crossing?
Is there any way to record motion on all area, but get email notification only on selected/drawn area?
Basically I am trying to set it up so I can have the camera record any motion even if it is not important or nearby event, but I want selected area to notify by email, for example if someone is coming by the door. I know I can do that with line crossing but it doesn't always work well and straight line doesn't always fit well to accomplish the task, if there would be a triangle instead of line would be much nicer. The camera doesn't support region entrance.
Also is there any way to change the resolution/size of images received by email? I don't see options for that.
Cheers.
Cheers.
