Motion Detection - How to make it "super sensitive"?
Lucas Tam
Apr 12, 2017
29
5
Hi all,
I have two cameras that I would like to trigger if they see any motion - I have Sense AI enabled so I'm not worried about false detections.
I have the following settings, but even then, it takes a few frames (1.5s) for motion to trigger. My cameras are 30 FPS with a 1.00 keyframe.
Object Detection is only enabled for "Reset Detector When...", "Object Travel" and other settings are disabled.
I've tried testing previous events with "Min. Object Size" set to the minimum, but the results seem to be the same?
I literally want a hair trigger so that I can pick up motion ASAP the moment someone walks into the FOV of the camera.
Any ideas?
