Ok, after a failed build of my video editing PC due to a bad motherboard, I have the Skylake i7 6700K CPU that I may consider using for a BI build.
I have an MicroATX case from a former HTPC build that I can use for a dedicated BI system. Question is, what's a decent mATX board I can use that's reliable to run BI on? Asus I know is usually in most cases used for high end builds, but I need to find an mATX board that will be compatible with the 6700K.
It will probably be the only system I will install Windows 8.1 on and utilize the iGPU on the CPU.
Thanks!
Thanks!
