fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,411
You have proved the point. My point was that IF you homerun as REQUIRED by tvi, then its the SAME plug and play.No, I almost NEVER homerun IP direct to the NVR. That defeats the entire purpose of IP in that they give you network flexibility. My IP cams get run to a PoE switch which is then run to the NVR so you can access each individual camera to make changes, adjustments, etc. as necessary.
Now please edify me on how I can remotely hack into a TVI camera. The CAMERA, not the DVR.
You cannot hack a tvi camera but you CAN hack a TVI dvr. You also cannot hack an IP camera that his homerun to the NVR unless you first hack the NVR since the NVR places them on their own subnet. Thus, they share the same risk.
While the ability to network the cameras so you dont need a home run, is one advantage of ip there are many others, including SD card storage and the ability to stream to multiple recording locations...
