Monitor resolution w/o Monitor
nutshellml
Jun 22, 2016
195
15
Not directly a BI issue, but on my dedicated BI computer, I don't have a monitor, I'm using team-viewer from my main computer when I need to set something up. That said, for some reason I cannot change the display to anything but 640x480, the display adapter is the generic microsoft from 2006 and I can't change it. Any thoughts to force a display? So when I loggon in teamviewer it's somewhat normal?
Reactions: nutshellml
Can't everything is grayed out in teamviewr.
@fenderman can you explain again why the Intel card is better then the add-on card. I ask not questioning, just want to know for myself.
The built in Intel graphics are more energy-efficient, and usually can be used for hardware accelerated H.264 decoding which further increases Blue Iris efficiency.
Reactions: fenderman
