Hi All,
I've got a Hikvision DS-7608NI-E2/8P with 8 POE terminals (Firmware: v3.3.18 POE ports)
connected to:
1x DS-2CD2332-I2 v5.2.5 Build 141201
6x DS-2CD2232-I5 v5.2.5 Build 141201
My question is, if I'm using the Hikvision DDNS service, is it important to change the camera's passwords for security reasons? I've done this, but the problem is, I then have to select to manually add the cameras with a static IP address, as that's the only way I can nominate a password. Plug and play won't seem to let me specify a password (ie it uses the default camera password).
Does anyone know how to use the plug and play camera adding on the Hikvsion NVR, and specify your own password?
Thanks in advance
connected to:
Thanks in advance
