orange13th.02 n3wb May 22, 2023 4 1 Vietnam Jun 7, 2024 #1 I'm a security engineer, I can modify the firmware every version of dahua NVR. Can I make money doing this??
bigredfish IPCT+ Member Sep 5, 2016 32,935 79,984 The Swamp Jun 7, 2024 #2 Guess it depends on the definition of “modify” and whether you like to operate in the dark Reactions: David L
T tigerwillow1 Known around here Jul 18, 2016 5,312 12,226 USA, Oregon Jun 7, 2024 #3 Are you a bot? Reactions: David L and bigredfish
orange13th.02 n3wb May 22, 2023 4 1 Vietnam Jun 9, 2024 #4 bigredfish said: Guess it depends on the definition of “modify” and whether you like to operate in the dark Click to expand... Exactly, I can patch the kernel and uboot so I can change the firmware at will. I just need the opportunity to make money
orange13th.02 n3wb May 22, 2023 4 1 Vietnam Jun 9, 2024 #5 tigerwillow1 said: Are you a bot? Click to expand... Do not think so :'( Reactions: tigerwillow1
P [email protected] Getting comfortable Dec 4, 2015 501 581 Jun 9, 2024 #6 You could contact Dahua/Hikvision or even Reolink to check if they have any job vacancies? Reactions: bigredfish
orange13th.02 n3wb May 22, 2023 4 1 Vietnam Jun 9, 2024 #7 [email protected] said: You could contact Dahua/Hikvision or even Reolink to check if they have any job vacancies? Click to expand... lol =))
