Modified Synology SS .conf file for Hikvision 2CD2135F-IS and or 2CD2145F-IS models?
DEADBEEF
Apr 4, 2016
11
3
I've been using the Onvif generic config so far during testing, which works ok but doesn't allow a direct camera stream in liveview or on mobile.
It's also not possible to add Onvif cameras in batches, which is a handy feature. I think there are quite a few other settings and options missing as well.
Synology are being their usual slow-assed selves and haven't got round to adding full support for these cameras yet.
I've had a play around making a copy of and adapting the config settings for the 2CD2142F-x and 2CD2132F-x models, but so far haven't been overly successful.
Before I spend any more time on this I just thought I'd check here to see if anyone has already been through and figured out the correct config options? (no sense in covering the same ground twice).
Cheers.
