J Jsitechnical IPCT+ Member Feb 12, 2023 7 0 San Antonio Feb 16, 2024 #1 Hello, When I log into the mobile server for Blue Iris, I keep getting kicked out of the UI3 after logging in. Has anyone else dealt with this issue before ? I can’t keep control of my cameras like this.
Ssayer BIT Beta Team Jan 5, 2016 19,733 71,534 SE Michigan USA Feb 16, 2024 #2 Immediately? After XX amount of time? Or??
J Jsitechnical IPCT+ Member Feb 12, 2023 7 0 San Antonio Feb 16, 2024 #3 Almost immediately , I get an error and it restarts itself.
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,326 48,133 Alabama Feb 16, 2024 #4 Jsitechnical said: Almost immediately , I get an error and it restarts itself. Click to expand... Can you attach screenshot of error?
wittaj IPCT Contributor Apr 28, 2019 30,849 59,196 USA Feb 16, 2024 #5 Sounds like you might be overloading the feed. Are you using substreams? What version of BI are you on?
J Jsitechnical IPCT+ Member Feb 12, 2023 7 0 San Antonio Feb 16, 2024 #6 Yes I am using substreams. I’m on the latest stable version.
