Hi
I am setting up BlueIris as a dashcam / full car surveillance system and cannot get audio from my USB webcams to work.
If I try and enable audio the stream then stops with - no signal 80004005 () 1006.
I have chosen to use 5 x 2MP webcams for this setup as they will draw power directly from the micro PC's USB ports. The specs of the micro PC are fine. All within the requirements for the number of cameras etc.
I was going to use 5 x 12v IP Cameras. However, decided against this as I would then need a switch, and would need to power the switch and cameras.... additional cabling.
I settled on the micro PC and USB cameras as I then only need to power the PC. Which is done via the car having appropriate power.... DC to DC charge, 300W solar, 100ah lithium battery.......
The system will work perfectly if I can just get audio to work with these particular webcams.
Windows and Blueiris detect the cameras as "USB 2.0 Camera". Video works perfectly. Only an issue with enabling audio as it does not seem to detect the webcam as an audio device.
