Missing the face detection option in my NVR dahua
Ram2693
Jun 1, 2024
3
Australia
Really want to set up the face detection/ face recognition options.
However every video the first step is to go to AI option then parameters then smart plan and select “face detection” for the required channel.
I don’t have that option which then doesn’t let me continue. (See image attached)
Please help it’s really frustrating at this point and I have contacted the supplier and they noted that my model of NVR does allow it and should work. But they are no help after that.
I see face detection and face recognition in your screenshot to the left - does it not let you select it?
However many of us would prefer to use IVS for human detection instead of face detection.
Reactions: Ram2693
If your smart plan does not have FD for that camera, than the camera in not capable of that feature.
You would either need a different camera or a AI NVR that allows a few channels to do FD by the recorder.
This
What model is the camera and what model is the NVR?
Reactions: Ram2693
Thank you all for the quick responses:
Please see below the items I have:
1. NVR: DHI-NVR4216-16P-AIANZ-4TB
2. CAMERA: DH-IPC-HDW3666EMP-S-AUS-BLK
OK both appear capable of IVS (perimeter protection) but the camera does NOT have Face Detection capability.
(Side note: That camera wont be very good at night without a LOT of external light. Its a small sensor on a 6MP camera)
Because that is one of the new 'AI" NVRs (budget model), in theory you should be able to do FD by NVR for 1 channel only
1st you need to get out of the machine interface, open a web browser and go to the IP of your NVR and login via the browser
I dont have one of those AI recorders so I cant tell you exactly where, but there should be a switch to choose "AI by Recorder" for the selected channel
Thank you I tried all that but without the option in the smart pla for face detection it for some reason does not work?
Like video link below
As bigredfish suggested. You need to enable "AI by the recorder". The user manual for your NVR will hopefully guide you further.
