Missing PTZ edit button
Tinder
Dec 9, 2017
3
Germany, Munich
I have a Wansview Q3S and managed to get a live stream with the
Wansview NCB521W RTSP/HTTP from the list, since the Q3S is not
(yet) in the list.
Camera properties -> PTZ/Control: The user manual says
"If you select *CUSTOM* at the top of the device list, you may use the
Edit button to specify the HTTP requests used for all PTZ commands."
But there is no *CUSTOM* entry in this list. Also there's no PTZ edit
button. Maybe I'm missing a setting in other location?
(yet) in the list.
its the very first option on the list...you should have an edit button...delete the camera from blue iris and add it back..
Deleting & adding back the camera doesn't help. Installing an old Instar PTZ camera doesn't fix the issue. BI re-install doesn't fix the issue. The same story with a fresh installed & patched Windows 10 x64 VM without any additional software.
I have no *CUSTOM* first entry in the list, no *CUSTOM* entry elsewhere in the list and no edit button.
The real metal is Windows 10 x64 with latest patch level, Core i7 [email protected], 32GB Ram, Intel HD Graphics 4600 (Acer Incorporated [ALI]), 4095MB NVIDIA GeForce GT 750M (Acer Incorporated [ALI])
EDIT: I just downloaded a fresh installer copy. Now ist works flawlessly. I don't understand, maybe the first installer was corrupted while downloading...
I've got this (below) for any cam, not even a PTZ; BI is version 4.5.7.3 x64, What is yours?
Select *CUSTOM HTTP* at top of drop-down then 'Edit' button is no longer greyed-out.
Select 'Edit' then 'edit PTZ HTTP' pops up.
@TonyR: Thank you for the explanation & screenshot. Please see EDIT in my post above. Very strange...
This case seems to be closed.
A 'happy ending'! :cool:
