Danica POE NVR lost feed from Dahua turret connected using lr002? Passive coax Ethernet balum. Purchased a new turret and Ethernet to coax balumns and still not working. Set up test connections in house and it’s not working. Swapped ports and the other wired cam works fine. Connected new turret with Ethernet and it works. I have not measured voltage but the symptoms suggest it may be the Poe switch lost it’s voltage or the adapters aren’t working.
any ideas?
any ideas?
