Hi all,
i'm fetching TrafficJunction events from multiple cameras via python script http request to filter recognized plate numbers and check for access permissions.
This works fine most of the time. But some events don't come through. Approximatly 1 of 20 events is missing if i compare the logs from my receiver to the logs of the cam.
My script seems to work fine because events from the integrated device testing function (from the WebUI) are all received without a single fail.
For testing i installed a javascript in the browser which fires a test trigger every second (which is way more than the real life events).
So i have two questions:
Is there a difference between "Test triggered" TrafficJunction events and camera triggered events?
Did someone else experince these event subscription fails and maybe has a good idea how to fix this?
Used cams: Dahua
type=DHI-ITC413-PW4D-Z1
Hardware version=1.00
Software version=5.003.0000000.0.R,build:2024-07-19
Used cams: Dahua
