Hello,
Enabled BI to auto start as a service and when I also try to start the interactive UI, the main view is just a black rectangle, the cameras are not visible. Note that if I right click into the black rectangle, the per camera context menu opens, so the mouse click events are still getting processed correctly, just nothing is visible. If I disable the service start, all is back to normal with cameras being visible. Though when I reenable service start, the same happens again.
The main reason this is bothering me is that if I want to just tweak a camera parameter, I would like to turn on the UI, tweak it, and then continue as a service. Is that possible or do I always need to disable service, restart UI, make a change, reenable service?
As is, this is what my UI looks like while the service is enabled (cropped the left and bottom tabs for privacy):
![1714456139541.png](/data/attachments/193/193639-c109f2691ce0ce6a4473aaedc30dcee3.jpg)
Thanks,
Jiri
Thanks,
Jiri
