Mini-review: Dahua VCS-SH30 PoE speaker
ATX
Aug 3, 2020
7
13
Austin, TX
I bought the Dahua VCS-SH30 PoE speaker from @EMPIRETECANDY a while back and finally got around to mounting it outside.
For pole mounting I used the PK-088 kit from Polycase.
The speaker has 512MB internal memory and supports expansion via MicroSD slot. I installed a Samsung Pro Plus 128GB MicroSD and the full capacity is recognized.
Speaker amp power is 15W, which is plenty loud for my use.
The SIP protocol support is pretty useless (to me) as it limits you to 8KHz audio (G.711 codec).
Best audio quality is achieved by uploading MP3s to the speaker and playing from storage.
Here's a python script you can use to upload and play MP3s.
If anyone from Dahua is reading this: please open source the firmware so we can add support for a modern streaming protocol like AirPlay.
View attachment speaker.mp4
Is there more (connector, fitting, bushing, etc.) that you didn't show where the CAT cable enters that threaded entrance?
I ask because surely that doesn't look like it would be OK outdoors. :cool:
Yes :) The threaded metal cap (seals with a giant O-ring) is removed in that photo to reveal the MicroSD slot.
The end of the cable has a waterproof Ethernet connector and a DC power input (optional, since PoE is supported).
I thought it is just a normal speaker, :D but This one price is high. 300usd+.
It is indeed pricey, but if you actually need a PoE speaker there's not much competition. Axis makes one, but of course being Axis it's even more expensive (around 600 USD).
Hello,
I'm trying to use the Python code, but I'm getting an error when entering my username and password. I'm getting an error saying I'm missing a token. Apparently, the system uses special encryption or something. Is there a way around this?
Thanks.
The password is part of the code, What it should do is ask for a password. You enter the password and then it should do what you want it to.. You could update the code to have the password in the code, I personally don't like that it is setup with user LIC info..
Also not sure but looking at the code there might be a mis spelling in the code as well? there is a line that has uer and my guess is that was meant to be user.. Just saying what I see? Not sure what as I don't have this speaker for testing the code.. For all I know the Lic info is part of the speaker I don't know, Just odd to me..
The default password for the speaker is admin, this speaker best to use with 5 series nvr with special fw too. I have a client use this speaker for the projects a lot, latest new fw is available.
