- Mar 27, 2014
- 3,137
- 750
Before purchasing the camera please be aware of the following issues/limitations that were previously reported:
Power - Some users including myself had issues with POE. In my case it was resolved by using a another POE switch. Make sure POE meets the requirement. Camera tests show that it draws up to 11W. (spec state up to 18W)
Focus - 1 user reported focus issue after fog, camera wouldn't auto refocus. Resolution: manually focus
PT movement speed - Slow pan/tilt movement. This is a known camera limitation
Internal wiring issues - No details on this yet
In camera motion detection - Too sensitive and sends out numerous false alarms. Especially during dusk/dawn hours. Resolution: None so far if you are relying on builtin firmware. I couldn't get any input from the supplier whether this will be fixed
Slow shipment from the supplier - camera is currently in high demand and shipment maybe slow. Resolution: Be patient
Stuck IR cut filter - reported by 1 user. Resolution: power cycle the camera
I will be updating this post as more issues get reported
