Actually it seems to be grounding problem that was causing interference. I took a speaker wire and attached other end to mic's body. Other end had to be grounded to one of the usb audio interface device's coupling. At the moment that seems to fix my issue. Earlier I really tried to ground microphone to everything and today I was just wasting time and playing around with the speaker wire.. couldn't believe that grounding has to be between microphone and usb audio interface..where is already rca cable connected. Hope this helps others out there. Without grounding audio might work few weeks and then suddenly start to buzz. I fixed buzzzing issue earlier without changing anything (it just stopped buzzing) but now it seems like this could be permanent fix.
