D Dennis Ward n3wb Nov 2, 2018 16 7 Fuquay Varina, NC Nov 17, 2018 #1 Does BI support the retrieval of clips from the SD card ? Thanks Dennis
fenderman Staff member Mar 9, 2014 36,891 21,417 Nov 17, 2018 #2 Dennis Ward said: Does BI support the retrieval of clips from the SD card ? Thanks Dennis Click to expand... No... SD card as a backup source... If it's ever necessary you can manually do it.. Reactions: Dennis Ward
