Hi,
Re: Mic Background Noise on IP Camera DIY Install.
I am getting a buzz/throbbing noise from a separate microphone - which is plugged into my IP camera, I can hear sound from within the CMS software, but it is mostly obscured by the noise - it is quite loud, any ideas why would be helpful.
I have purchased one of these:
720p Pin Hole IP Camera
http://www.elpcctv.com/720p-mini-pi...camera-with-1280x720p-hd-resolution-p-46.html
and one of these:
CCTV Camera Mic.
http://www.ebay.co.uk/itm/310932069240?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I have the microphone's white plug, plugged into the white connector on the Camera (yes the camera has one of these), a POE connector feeds power - first to the Mic, then on to the camera (black and red connectors) - I have an image, but cant seem to post it up.
I have tried just laying the mic. lose on a surface (it was pushed into a hole) - at least a foot away from the camera, to rule out interference. I have also put my finger over the mic - but that too made no difference.
Any pointers would be helpful.
and one of these:
CCTV Camera Mic.
