I have what can best be described as a compound. It covers an acre with three different buildings spanning about 200 feet from one end to the other of the buildings. All of the buildings have metal roofs which pretty much destroys wifi outside of the buildings. I currently have a Google Mesh setup with six pucks/APs/whatevertheycallthem, and am not happy. I am not happy because all but one of the APs is hardwired. The problem began several months ago when one of them decided to go mesh instead of hard wired. Remember those metal roofs? Yeah, mesh building to building don't work. The 20 year old CAT5 cable running between buildings tests from computer to computer at 600 - 800 Mbps reliably, never seen a glitch, which I think is pretty good going through a couple of switches along the way.
But add in a fifth AP, and it goes to heck. Add in the fifth, four wired, and it all goes to mesh, not using the wired backhaul. It is obvious because the speeds drop off to like 10-30 Mbps, from 150-250 Mbps to SpeedTest.net. I've changed out patch cables, swapped APs for different locations, swapped PSs, rebooted everything, nothing works. If I take the one off line in the furthest building, it works, add either one back, and POOF! Gone! I currently have a very old router setup as an AP for that building, but it is a kludge, with a different SSID.
I'm considering just replacing the whole mess, but that would be expensive. I have Comcast/Xfinity and my own modem, then use the Googles for the wifi. I would need at least five APs, two in one building, one in each of the other two, and one repeater/mesh in attic, although I could hard wire that.
1. Any google Wifi experts know how to kick these damned things hard enough to get them to work?
2. Can I mix and match APs with the same SSIDs and not create issues? I have a whole box of older routers I could reconfigure as APs.
3. If not, any recommendations?
